04-06-2019, 05:18 PM
Isn't it 5.625, 8x45 teeth ?
The Big 7 diff is different in that the 1/2 shafts are larger requiring special bearings,(Reduced o/d I think) either side of diff to fit and boring out of the side tubes, I don't think the CWP ratio was any lower either ?
If you are running a 4 sp box you wouldn't need that low a ratio.
