Flywheel locking tool
Must feel frightful posh to own a car which doesn't wee oil everywhere it stops...
Thank you all for the information. The photo makes it clear where and how it is fitted to the flywheel thanks again.
John Mason
HI All,
Before ordering a SPEEDI-SLEEVE the Dia of the shaft needs to be measured accurately because the min & max is only .006 th regardless of sleeve Dia.
Also the 99187 that Steve Jones uses is 5/16 narrower than the 99186 this allows the sleeve to Fit better on the shaft they should not be level with the end of the shaft but further on leaving a gap between end of shaft and sleeve and Definitely not Peened over
Colin
NZ
Ooops - Mine's peened over. I'll deal with it when I get round to assembly.
