10-03-2019, 02:03 PM
It could be, someone felt they should put double clutch springs in the car. Because it's a sports model.
This can make the clutch very harsh, to the extent that it will stall with medium throttle. And lurch forward with a high throttle.
If you have the car useable, it can be worth useing as is. And see if you get used to it.
If you have to do other work, put it on the check list.
Tony.
Tony.
