All the hub carriers that I have dealt with over the years have had one piece studs as per the drawing posted earlier
Your stud has pulled through the flanged part and gives the impression that it was welded, it has not.
I agree with Robert on this one, I have also seen a lot of hub carriers and I have yet to come across one with studs made from two parts.
Wouldn't it be sensible to drill the holes in the hub & studs to accept the slightly larger (presumably metric) rivet? Surely all these rivets do is hold the stud in position, they are hardly "safety critical". The main clamping force is applied when the wheel nuts are done up.
Dennis, you may not expect it but I can assure you it happens. I imagine you are simply getting confused thinking about the force needed to pull a new stud, rather the gradual demise from years of repetitive over tightening and cornering force. As Robert has already brought to your attention the sharp corner is a stress riser, and a nice round one through a thin flange at that. Think about it again inspect a few dozen more hub carriers and perhaps your expectations will change.
After struggling to fit 'new' studs, in my case ex John Barlow because a) the rivet holes were in the wrong place, and b) the thread was oversize so I had to run a die nut down it. I decided that in future I shall use ht cap head bolts as wheel studs suitably shaped at the head end with an angle grinder and tack welded to prevent rotation.
Has anyone ever done this.
