10-06-2018, 11:46 AM
I might be able to help you Bryan, give me a call.
Easter Run
10-06-2018, 12:00 PM
(10-06-2018, 09:31 AM)Colin Wilks Wrote: Is the castellated nut and split pin part of the problem? If there were no split pin (as I think Bob Culver has recommended) nipping up the nut periodically would be an easier and more obvious thing to do as part of regular maintenance. My view of such an axle situation is to take the plunge and replace the shafts which have been incorrectly fitted. The crown wheel and pinion set has "had it" and needs replacement. Bearings (good quality only) and hub outers, lip seals for the diff are a good idea. Main thing is to get someone who knows how to set it up, or all is wasted ! All the parts are available from David Cochrane. Done like this it should never need attention for a massive milage of normal motoring. As to tightening axle nuts, if they fit the hubs properly once tight, that's it they are tight. |
