As someone who makes Austin Seven timber frames for a living, this makes no sense at all.
If one was trying to counteract some imagined effect of twisting or flexing I'd have thought that a mix of right and left-handed threads would be necessary on BOTH sides of the body - in other words, say, RH on the hinge side and LH on the lock side of one door and the other way about on the other door.
I have read this string with great interest. I know this does not really answer the question but I think it was designed by someone with s screw loose (left or right handed thread)
John Mason
The other thing that puzzles me is that the screws are brass, my understanding is that steel or iron screws would have been used in the ash frame (that’s certainly what is used in both my Delage and Rover) Martin is this correct?
If I was putting a brass screw into hardwood I'd put a steel one in first, take it out, then put the brass one in. Doesn't seem like a faff as using "proper screws" is such a rare treat now rather than the modern super sharp pozi drive types.
Does (did) anyone wax screws before putting them in?
While we are on this topic perhaps some contributors would be interested in how I managed to remove some rusty wood screws from an Ash frame. The Spare wheel carrier on my 1930 Austin Swallow saloon needed to be removed to replace the rivets holding the wheel retaining studs in the boss. The wood screws were rusted so tight that the heads would just break off if I tried to undo them. The answer I found was to rest a hot soldering iron against the screw head until the heat did it's work and the rusted screws could be removed easily.
Maybe of use to someone one day.
Hi Ray,
Wish I had known this when I did my Ruby woodwork 20 years ago - yes, all the screws were steel and rusted.
And to those patiently reading this far through the thread, please forgive the loose screw as we finally reach April 1st.
Colin
