29-06-2020, 09:15 AM
If you have replaced the ignition warning light with a link the dynamator will be supplying power to the coil when then engine is running even with the ignition switch in the off position.
6V Dynamator - first hand experiences...
29-06-2020, 09:21 AM
Have you connected 'D' to anything? With no ignition light then D should connect to nothing. If you have connected D straight through, to the ignition coil, then disconnect it.
29-06-2020, 09:31 AM
Thanks chaps, the car has no ignition lamp and hence the wiring just goes as though this was bypassed and linked straight through. I do have "D" connected to the coil. If I disconnect this, will it have any effect to the charging? I'm thinking the correct answer is to install an ignition lamp right?
24-03-2021, 10:30 PM
Hi Robbie did you manage to get the issue sorted out . I have also had the same problem although I do have an ignition lamp on my switch panel . The lamp does not go off when the car is running and when I switch ignition off it also does not stop . D on my panel is grounded ? Any advice
25-03-2021, 10:04 AM
Hi Kenny, yes all fixed. I disconnected the wire connected to "D" and all sorted. This is due to not having an ignition lamp it seems...
