05-12-2019, 09:31 PM
Thank you all for the words of praise. Still no finder's of the anomaly?
05-12-2019, 09:43 PM
Should be a lock washer between the gland nut and the locking nut.
05-12-2019, 11:22 PM
Number sequence?
05-12-2019, 11:23 PM
Well spotted Chris, but that's not the anomaly.
06-12-2019, 04:48 AM
Robert
Would that hub just happen to have 4 wheel studs? The stud holes seem a bit close together. Peter
07-12-2019, 12:41 AM
The spacing seems more like 5 stud to me?
07-12-2019, 07:09 PM
Different base plate diameter?
07-12-2019, 07:24 PM
Hi Robert
Is flange on the pinion shaft is for a UJ propshaft, (not sure what it’s from). The other is the standard Cardenas block flange? Cheers Howard
07-12-2019, 08:28 PM
Hello Howard,
yes it's a Ruby flange, screwcut and with a new gland nut fitted to enable a Ruby propshaft to be fitted to an early 1928 axle. |
