  • 4 Vote(s) - 2.25 Average
Restoring a Top Hat
It would be interesting to know how the brakes balance, also with the brake pedal there where does the clutch pedal go Ruairidh?
Here Dave...
.jpeg   73EDC967-16D3-4A99-8C04-CF9E665DE356_1_105_c.jpeg (Size: 57.32 KB / Downloads: 533)
The throttle linkage is an absolute hoot! Will try and find the picture.
.jpeg   077CBD3E-5F5E-4F34-8F42-BD6BF437B290_1_105_c.jpeg (Size: 61.16 KB / Downloads: 522)
.jpeg   D73A2DAF-B42D-4568-BA29-88D462E33097_1_105_c.jpeg (Size: 66.74 KB / Downloads: 522)
.jpeg   DB2CC887-56A0-458F-8B65-BC7C57BDEE5B_1_105_c.jpeg (Size: 70.82 KB / Downloads: 522)
.jpeg   5CB19847-66C2-49BF-A8F8-7B6FA4B76B2D_1_105_c.jpeg (Size: 48.43 KB / Downloads: 522)
.jpeg   9D5DDD32-DA11-414B-A345-3ED76221FF6C_1_105_c.jpeg (Size: 73.84 KB / Downloads: 522)
That tiny throttle linkage is hilarious!
I thought the engine was mirror image ?
(20-05-2020, 11:36 PM)Tony Press Wrote: I thought the engine was mirror image ?
This must be a Willys/Overland/Crossley LHD car built in Berlin from SKD Longbridge components.
The mirror image engined cars were built by Dixi/BMW at Eisenach.
Thank you for this  Smile
This weeks work
Or rather last week, I'm all behind!
I was still stuck waiting for the engine bits to return so decided to have a go at the front inner wings. Didn't have a lot of time last week as I had to work 2 1/2 days but managed to sort them out.
The offside wasn't too bad, some badly MIG'd over-patches had to be ground off and new metal let in properly. I don't usually bother to grind off the weld beads, they add character I feel!
Nearside was in a poor state though, the panel had been repaired several times and was in a bad way. I had to chop off the last inch and let new metal in and then bend it in the right place. I think it's OK, we'll see when I start fitting the front wings......
Fortunately, the balancing shop is back in business and rang at the end of the week, so I went down and collected the crankshaft/flywheel/clutch/rods assembly on Friday (observing correct social distancing rules of course). This week is all about engine rebuilding, which I want finished by Sunday. I have a couple of weeks left but I'm then back to work full-time in June......
Excellent
But work.... “Curse of the Austin Seven Classes”....
Retired 17 years ago ?.
As you say that is a hoot whilst the clutch pedal is interesting.
