Cutting Narrow Strips of Metal
Vaguely Austin Seven related:
I wish to use my set of bench shears to cut strips of metal approximately 4mm wide. They need to be parallel and of consistent size.
The strip is narrower than the thickness of the blade, making it difficult to use a conventional fence or stop as the blade would hit the stop.
Does anyone have a suggestion how to set up an adjustable stop so that I cut the strips consistently and without having to measure each one?
Thank you.
Jamie
Cutting Narrow Strips of Metal - by Jamie - 29-02-2024, 01:56 PM
RE: Cutting Narrow Strips of Metal - by jpsmit - 29-02-2024, 02:49 PM
RE: Cutting Narrow Strips of Metal - by Tiger - 01-03-2024, 07:12 AM
RE: Cutting Narrow Strips of Metal - by Jamie - 01-03-2024, 09:03 AM
RE: Cutting Narrow Strips of Metal - by Jamie - 02-03-2024, 09:52 AM
RE: Cutting Narrow Strips of Metal - by Jamie - 04-03-2024, 08:55 AM
RE: Cutting Narrow Strips of Metal - by Jamie - 05-03-2024, 08:28 AM
