RP Tappet noise
Both are very important Graham, if you have more than 3 thou end float the cam will kick back an forth making all sorts of clatter, it will wear the front bush quickly and eventually cause an oil leak around the locating pin. Others may have differing opinion about lash but I find 4 to 5 thou about right, its important when mixing and matching gears that you stone off high points or you will point load the teeth which in bad cases will cause fast wear and inevitable chipping of the gear.
RP Tappet noise - by Graham O - 16-02-2024, 06:38 AM
RE: RP Tappet noise - by John Cornforth - 16-02-2024, 11:07 AM
RE: RP Tappet noise - by Parazine - 16-02-2024, 12:26 PM
RE: RP Tappet noise - by David Stepney - 16-02-2024, 09:13 PM
RE: RP Tappet noise - by Chris KC - 16-02-2024, 11:48 PM
RE: RP Tappet noise - by Graham O - 17-02-2024, 01:49 AM
RE: RP Tappet noise - by Chris KC - 17-02-2024, 09:37 AM
RE: RP Tappet noise - by Malcolm Parker - 17-02-2024, 10:16 AM
RE: RP Tappet noise - by Steve Jones - 17-02-2024, 04:27 PM
RE: RP Tappet noise - by John Mason - 17-02-2024, 07:05 PM
RE: RP Tappet noise - by Graham O - 17-02-2024, 10:38 PM
RE: RP Tappet noise - by Graham O - 19-02-2024, 09:08 AM
RE: RP Tappet noise - by John Cornforth - 19-02-2024, 09:23 AM
RE: RP Tappet noise - by Ian Williams - 19-02-2024, 09:25 AM
RE: RP Tappet noise - by Graham O - 23-02-2024, 04:25 AM
RE: RP Tappet noise - by Ian Williams - 24-02-2024, 11:37 AM
RE: RP Tappet noise - by dickie65 - 24-02-2024, 05:28 PM
RE: RP Tappet noise - by Ian Williams - 24-02-2024, 09:41 PM
