17-02-2024, 10:16 AM
(This post was last modified: 17-02-2024, 10:20 AM by Malcolm Parker.)
If you flatten the cam followers, you generally need to reduce the height of the guides in the block. If you don't, the tappets foul at the top of the guide and the base of the cam follower will not seat on the camshaft. Could this be your problem?
