RP Tappet noise
Thanks for the comments.
I did not explain that the reason for the larger radius on the cam followers was to give a faster lift to the valves to give a better intake and exhaust passage.
I have also fitted a silicon gasket between the cylinder block and the crankcase.  That may have compressed and reduced the valve clearances a little.
The noise is consistent across the motor (i.e. all tappets) and is there at all speeds.
I don't remember refacing the tappet screw heads so I may have had a setting problem, but that would probably lead to some tappets being louder than others.
Graham
Slowly rebuilding a '34 RP
RP Tappet noise - by Graham O - 16-02-2024, 06:38 AM
RE: RP Tappet noise - by John Cornforth - 16-02-2024, 11:07 AM
RE: RP Tappet noise - by Parazine - 16-02-2024, 12:26 PM
RE: RP Tappet noise - by David Stepney - 16-02-2024, 09:13 PM
RE: RP Tappet noise - by Chris KC - 16-02-2024, 11:48 PM
RE: RP Tappet noise - by Graham O - 17-02-2024, 01:49 AM
RE: RP Tappet noise - by Chris KC - 17-02-2024, 09:37 AM
RE: RP Tappet noise - by Malcolm Parker - 17-02-2024, 10:16 AM
RE: RP Tappet noise - by Steve Jones - 17-02-2024, 04:27 PM
RE: RP Tappet noise - by John Mason - 17-02-2024, 07:05 PM
RE: RP Tappet noise - by Graham O - 17-02-2024, 10:38 PM
RE: RP Tappet noise - by Graham O - 19-02-2024, 09:08 AM
RE: RP Tappet noise - by John Cornforth - 19-02-2024, 09:23 AM
RE: RP Tappet noise - by Ian Williams - 19-02-2024, 09:25 AM
RE: RP Tappet noise - by Graham O - 23-02-2024, 04:25 AM
RE: RP Tappet noise - by Ian Williams - 24-02-2024, 11:37 AM
RE: RP Tappet noise - by dickie65 - 24-02-2024, 05:28 PM
RE: RP Tappet noise - by Ian Williams - 24-02-2024, 09:41 PM
