Rough running on 29 Chummy
Crack in the distributer cap, crack in the rotor arm, head gasket, inlet manifold gasket leak, plug leads - I am afraid the list could go on. If it was running OK before "Drive it day" , I would start with checking the distributer cap and look for cracks then check the compression of each cylinder with one of these
https://www.ebay.co.uk/itm/UK-Automotive...Swj2ZazysT
You are looking for equal compression on each cylinder - Preferably check when the engine is hot with the throttle wide open and all the spark plugs out. If one cylinder is way off, suspect the head gasket. You can check manifold leaks by squirting some propane gas around the joints whilst she is running and see if the engine behaves differently - do this outside !!
Good luck.
BobH
Rough running on 29 Chummy - by Ronaldo - 07-05-2018, 04:50 PM
RE: Rough running on 29 Chummy - by bob46320 - 07-05-2018, 05:07 PM
RE: Rough running on 29 Chummy - by Hugh Barnes - 07-05-2018, 05:23 PM
RE: Rough running on 29 Chummy - by Ronaldo - 07-05-2018, 05:29 PM
RE: Rough running on 29 Chummy - by Chris KC - 07-05-2018, 10:11 PM
RE: Rough running on 29 Chummy - by Dave Wortley - 07-05-2018, 10:42 PM
RE: Rough running on 29 Chummy - by john williams - 08-05-2018, 11:42 PM
RE: Rough running on 29 Chummy - by Ronaldo - 09-05-2018, 07:49 PM
RE: Rough running on 29 Chummy - by Ronaldo - 11-05-2018, 07:57 PM
