Fuel reserve tap accessory
Hi Steve
The tap you show a sketch of is for the later slab tank with the outlet under the edge of the tank.  I think it may be difficult to adapt for your D shaped scuttle tank that has a horizontal entry.
In any case your tank is quite small (mine take about 3 1/2 imperial gallons each fill giving a range of about 150 miles) so a spare can would be more useful.  I use a (sort of) wing mounted can containing about 1/2 imperial gallon, so far I’ve never needed to use it.  Duncan Grimmond makes a very nice spare fuel tank see this thread..https://www.austinsevenfriends.co.uk/forum/showthread.php?tid=6678
Fuel reserve tap accessory - by Steve Bryant - 08-01-2024, 03:08 PM
RE: Fuel reserve tap accessory - by AustinWood - 08-01-2024, 05:16 PM
RE: Fuel reserve tap accessory - by Steve Bryant - 20-01-2024, 10:40 PM
RE: Fuel reserve tap accessory - by Steve Bryant - 23-01-2024, 03:20 AM
RE: Fuel reserve tap accessory - by Howard Wright - 23-01-2024, 08:20 AM
RE: Fuel reserve tap accessory - by AustinWood - 23-01-2024, 12:17 PM
RE: Fuel reserve tap accessory - by Howard Wright - 23-01-2024, 12:21 PM
RE: Fuel reserve tap accessory - by Howard Wright - 23-01-2024, 01:40 PM
RE: Fuel reserve tap accessory - by Dave Mann - 23-01-2024, 04:37 PM
