Champion spark plugs 18mm
Hi
The only difference I can find is that the D16 (516) is pre-gapped at 0.025 inch and the D16J (564) is pre-gapped at 0.03 inch. I guess if you have a factory making thousands of engines it saves valuable time to be able to just screw them in without tweaking the gap.
Champion spark plugs 18mm - by Rogerpugs - 16-01-2024, 12:19 AM
RE: Champion spark plugs 18mm - by Tony Press - 16-01-2024, 01:57 AM
RE: Champion spark plugs 18mm - by Russlin - 16-01-2024, 08:41 AM
RE: Champion spark plugs 18mm - by John Cornforth - 16-01-2024, 09:02 AM
RE: Champion spark plugs 18mm - by Rogerpugs - 16-01-2024, 10:54 PM
