15-01-2024, 09:17 AM
(This post was last modified: 15-01-2024, 09:31 AM by Colin Morgan.)
Yes, on my car the tank was bolted in tight so there would be no movement - and so no wear. (There was some felt tape, as mentioned above.) If you cannot close the gap without stressing the tank, or alter it accordingly, I would suggest you might consider using a piece of solid packing of the right thickness to fill the gap - then there would be no movement where the tank passes through the bulkhead.
