05-05-2018, 06:09 PM
30watt x 2 is to high a current rating for an Austin dyamo to keep up with,this is 10 amps for the head lamps plus tail lamps then the current drawn by the coil. A much better solution would be to use L E Ds, a much better light output. Hope this helps.
