Flexible coupling fouls handbrake mount
Jon, the little bracket which screws into the back of the gearbox is usually quite worn where the handbrake lever rests against it, this allows the mechanism to go too far forward fouling the fabric joint mounting studs. The solution is to restore the length of the bracket by building up the end with weld or braze.
RE: Flexible coupling fouls handbrake mount - by Ian Williams - 04-05-2018, 08:14 PM
