Ruby Roof Rails drain holes
A big 'thank you' for that Denis...
You have said what I hoped you would say, that the f'wd hole coincides with the transverse section, such that any water running along it is scooted straight out to the side.
Also your pic seems to confirm that the full vertical 'side' of the rail is removed.
Based on the limited info available I think the RP is only different in the separation of the holes - it's noticeably less in the pics I posted (I'd still be delighted to receive a measurement from an RP though!)
On the sealant Denis, did you not find it hard to squish down? That 3M stuff seems fairly firm & clay-like.
I went halves on a pack with a chum but he has elected to use sealant from a cartridge instead - I haven't made my mind up yet as I'm still a little way off from that task.
Ruby Roof Rails drain holes - by Denis Sweeney - 17-11-2023, 10:50 AM
RE: Ruby Roof Rails drain holes - by Chris KC - 17-11-2023, 11:00 AM
RE: Ruby Roof Rails drain holes - by Chris KC - 17-11-2023, 11:17 AM
RE: Ruby Roof Rails drain holes - by Colin Morgan - 17-11-2023, 08:44 PM
RE: Ruby Roof Rails drain holes - by Chris KC - 17-11-2023, 10:53 PM
RE: Ruby Roof Rails drain holes - by Chris KC - 18-11-2023, 02:47 PM
