07-11-2023, 10:15 PM
It’s like a lot of Austin 7 things. The answer to both questions is yes, but it’s so much easier the other way. Regarding the timing, when I remove the dynamo what I do is turn the engine on the handle until the points are just opening on number one. Remove the dynamo to do whatever to it and be very careful not to turn the engine any. When you put it back just make sure it’s just opening the points on number one and you are good to go.
