Ruby door pins
Hi Stuart. One of the problems when dealing with the hinge pins is that they wear with big 'steps' in them, so it may be that that is stopping them coming out easily. Perhaps if a willing helper could be found that gently lifted the door making sure the pins were ideally aligned while you gently tapped might help? Do they move at all? The other thing that has been known to happen is that an earlier attempt at removing the pins has left the end burred over where hit with a blunt instrument...
hth...
Ruby door pins - by phillips - 16-10-2023, 03:27 PM
RE: Ruby door pins - by Hugh Barnes - 16-10-2023, 03:57 PM
RE: Ruby door pins - by Denis Sweeney - 16-10-2023, 04:29 PM
RE: Ruby door pins - by Chris KC - 16-10-2023, 05:01 PM
RE: Ruby door pins - by phillips - 16-10-2023, 05:26 PM
RE: Ruby door pins - by andrew34ruby - 16-10-2023, 08:45 PM
RE: Ruby door pins - by phillips - 17-10-2023, 07:28 PM
RE: Ruby door pins - by Dave Mann - 18-10-2023, 08:16 PM
RE: Ruby door pins - by phillips - 19-10-2023, 07:14 PM
