Bulkhead hole diameter
As grommets now all seem to be metric you'd be better off - as others have said - finding some that look to be correct and drilling according to the dimensions of the chosen one (I'd recommend experimenting first on a piece of suitable scrap metal sheet). BTW, the hole would originally have used not a rubber grommet, but one of the rather lovely, two-part, screw-together, nickel-plated metal type. Very similar ones canĀ still be obtained with a search on eBay turning up more than one supplier. Unfortunately, the gap between the two halves of these is greater than theĀ thickness of the bulkhead metal - hence they either need turning down (tricky) or a small washer found or made (very tricky) to compensate.
Bulkhead hole diameter - by Steve Bryant - 06-10-2023, 01:31 AM
RE: Bulkhead hole diameter - by Duncan Grimmond - 06-10-2023, 08:26 AM
RE: Bulkhead hole diameter - by Steve Bryant - 06-10-2023, 12:41 PM
RE: Bulkhead hole diameter - by Howard Wright - 06-10-2023, 12:52 PM
RE: Bulkhead hole diameter - by Tony Griffiths - 08-10-2023, 01:05 PM
RE: Bulkhead hole diameter - by Steve Bryant - 08-10-2023, 03:06 PM
RE: Bulkhead hole diameter - by Parazine - 08-10-2023, 07:43 PM
RE: Bulkhead hole diameter - by Chris Garner - 09-10-2023, 08:59 AM
RE: Bulkhead hole diameter - by Steve Bryant - 09-10-2023, 01:25 PM
