  • 1 Vote(s) - 3 Average
1937 Austin 7- 2 seater,Crank case Oil quantity?
#23
Congrats Jason
Well done.
I find the best way is to upload the video to YouTube and post the link here. Next time you fire it up check the oil pressure. Should be quite high at first but then drop to nearly zero once the oil is warm. If it stays high you may have a blocked oil jet.
As the car has a UK engine I would recommend you get the ‘Austin Seven Manual’ from Mercury Vintage Services, email susan.woodrow@gmail.com. The book is regularly referred to as ‘Woodrow’ and is a very good manual for all Austin Seven variants.
RE: 1937 Austin 7- 2 seater,Crank case Oil quantity? - by Howard Wright - 06-10-2023, 03:44 PM
