I set the fuel level the same as ALan when you operate the choke the fuel should flow over the top of the jet, nobody told me this as I learned from experience. When converting a HS2/HS4 carb to semi updraught I fit a disc to mount the float chamber so you can rotate the disc to get the fuel height correct,I don't lower the fuel height in the float chamber.(see photos)  Terry.
RE: What have you done today with your Austin Seven - by Terrytuned - 01-10-2023, 03:42 PM
