Shim washers
Bit of of a newbie question, but does anyone know a supplier of imperial shim washers?
I'm replacing the camshaft and crankshaft timing gears and was feeling quite pleased I'd got the camshaft end float dead on .002", but now need a .046" shim to bring the crankshaft pinion in line with the camshaft gear.
o/d is 1 3/4" and i/d is 1 1/8", so metric 42 x 30mm to give 1.15mm would do but is not ideal.
Being a lazy, mean Yorkshireman I'm wanting an off the shelf imperial alternative to buying yards of shim stock and making my own.
Shim washers - by Colin Wilks - 29-04-2018, 05:24 PM
RE: Shim washers - by MartinH - 29-04-2018, 05:34 PM
RE: Shim washers - by Robert Leigh - 30-04-2018, 11:08 AM
RE: Shim washers - by Colin Wilks - 30-04-2018, 02:10 PM
