Short chassis prop shaft lengths?
Hi,
I have seen a turned spacer fitted behind the carden block.
I used to have one but have not seen it for years.
I think I have a propshaft that has been cut and sleeved to change its length as well.
Anyone with a lathe and a lump of steel or aluminium should be able the make one for you.
Good Luck with your solution.
RE: Short chassis prop shaft lengths? - by JonE - 28-04-2018, 01:57 PM
RE: Short chassis prop shaft lengths? - by JonE - 29-04-2018, 01:32 PM
RE: Short chassis prop shaft lengths? - by dickie65 - 29-04-2018, 12:00 PM
