Peter if the threads you have stripped are the ones that screw the puller to the hub. You could try turning them off in a lathe if it leaves sufficient good threads for the puller to work.
John Mason.
RE: What have you done today with your Austin Seven - by John Mason - 13-09-2023, 05:00 PM
