Converting cut out to 12v
Hi
The shunt coil for a CFR2 should have a resistance of 33 to 39 ohms.  Other 6V cutouts will be similar.
I suggest you measure yours with an ohmmeter between the +D and Earth terminals.
Add an equal value resistor between the cutout earth and the car earth and it will now pull-in at  13 +/- 0.4 volts rather than 6.5 +/- 0.2 volts.
You might need a couple of resistors in series to get the right value, e.g. a 33 ohm plus a 3.3 ohm to get 36.3  ohms.
The higher the value, the higher the pull-in voltage
The resistor will dissipate just over a watt, so a wirewound type rated at 2 watts or more will suit.
Converting cut out to 12v - by 12jslater - 31-08-2023, 05:07 PM
RE: Converting cut out to 12v - by John Cornforth - 31-08-2023, 06:14 PM
RE: Converting cut out to 12v - by andrew34ruby - 31-08-2023, 09:57 PM
RE: Converting cut out to 12v - by PaulS - 01-09-2023, 03:10 PM
RE: Converting cut out to 12v - by 12jslater - 04-09-2023, 01:31 PM
RE: Converting cut out to 12v - by andrew34ruby - 04-09-2023, 01:48 PM
RE: Converting cut out to 12v - by PaulS - 14-09-2023, 05:26 PM
RE: Converting cut out to 12v - by John Cornforth - 14-09-2023, 08:28 PM
