Rev Counter Drive
The cable run depends on where your rev counter is fitted,Allow for a generous curve out of the distributor back to the dashboard.
Try and guesstimate the length of Cable you need as an inch or two each way and it won’t fit well.
If you have any speedo cable, armoured type try and use that to mock up to get the length you need.
Rev Counter Drive - by John P - 30-07-2023, 05:25 PM
RE: Rev Counter Drive - by PaulS - 15-08-2023, 06:52 PM
RE: Rev Counter Drive - by Austin in the Shed - 31-08-2023, 10:17 AM
RE: Rev Counter Drive - by Austin in the Shed - 31-08-2023, 11:20 AM
