Cutout issues (again)
Hi Harry
The Cathode of the Texas SM74611 chip (Tab and centre Pin 2) connects in place of the A terminal of the cutout. This then usually feeds via the Charge/Lighting switch through the Ammeter and then to the Battery positive.
The Anode of the 74611 (Outer Pins 1 and 3, connected together) connects in place of the D terminal of the cutout. This is fed from the main D output of the dynamo.
Current flow when charging is from Anode to Cathode
The average heat dissipation of this device is less than a quarter of a watt, so the package should not need any additional heat sink.
Later cars like the Ruby had a cutout which also incorporated the resistor for the "half charge" circuit. You will have to make separate arrangements if you want the half charge feature.
Cutout issues (again) - by JoeRowing - 13-08-2022, 05:42 PM
RE: Cutout issues (again) - by Ivor Hawkins - 13-08-2022, 06:23 PM
RE: Cutout issues (again) - by David Stepney - 13-08-2022, 07:58 PM
RE: Cutout issues (again) - by JoeRowing - 13-08-2022, 11:02 PM
RE: Cutout issues (again) - by bob46320 - 14-08-2022, 07:17 AM
RE: Cutout issues (again) - by Howard Wright - 14-08-2022, 07:32 AM
RE: Cutout issues (again) - by JoeRowing - 14-08-2022, 09:40 AM
RE: Cutout issues (again) - by JoeRowing - 14-08-2022, 01:20 PM
RE: Cutout issues (again) - by John Cornforth - 14-08-2022, 02:27 PM
RE: Cutout issues (again) - by Ray White - 14-08-2022, 04:12 PM
RE: Cutout issues (again) - by JoeRowing - 14-08-2022, 05:07 PM
RE: Cutout issues (again) - by daveg - 14-08-2022, 05:48 PM
RE: Cutout issues (again) - by HarryAusten7 - 30-08-2023, 08:17 AM
RE: Cutout issues (again) - by John Cornforth - 30-08-2023, 11:45 AM
