Damper tightness front and back
Assemble the arms mounted to the car, the links at the end not yet connected to the axle. As you gradually tighten up the nuts on the tension spring, keep gently pulling down on the end of the arm with a spring balance. When it takes the spring balance to be showing 12lbs when the arm just starts to move, then you have reached the desired setting.. Lock up the nuts and connect the aluminium link to the axle case (or beam in the case of the front axle)
Others may have a different approach, but this works for me...
Damper tightness front and back - by morrisminor - 21-08-2023, 08:23 PM
RE: Damper tightness front and back - by squeak - 21-08-2023, 10:27 PM
RE: Damper tightness front and back - by Hugh Barnes - 22-08-2023, 10:18 AM
RE: Damper tightness front and back - by squeak - 24-08-2023, 11:23 PM
