18-08-2023, 10:14 AM
If the pump is squeaking, this usually means that the bearings have been running dry and are on their way out. Lubrication may be a temporary fix, but, since an A series water pump is about 20 quid or so, I would be inclined to simply replace it. It isn't difficult to do, but remember to fit the bypass hose as you offer the pump back to the front of the engine. They are a bit fiddly to do with the pump bolted up.
