Speedi-Sleeve Query - Advice Please
Hi,
Having been given lots of helpful advice on here I bought a speedi-sleeve to fit to the flywheel boss.
The part number was 99187 which was as recommended by a number of people and, now that I have the flywheel off, it certainly seems the correct diameter.
My only concern is that the total length of the sleeve including the flanged part is approximately 0.694" whereas the length of the flywheel boss is just 0.530".
If I were to fit the sleeve as is and then remove the flange as per the instructions, the length would probably be OK but I would have to push the sleeve the last few millimeters by tapping it on the thin edge which doesn't sound likely to succeed.
Alternatively I suppose I could attempt to cut the sleeve down once it was fitted but I can't really see how I could do that with just hand tools.
Any suggestions?
John.
Speedi-Sleeve Query - Advice Please - by John P - 09-07-2023, 05:12 PM
