Emulsion block and butterfly
That's very helpful John, thank you. I lapped the emulsion block onto the bowl a couple of years ago when it began leaking. A very easy fix I thought but the replacement gasket seems not to have been petrol proof and had swollen up into all the void areas. Now assembled with a new gasket of a different make.
I suspect if this is main-jet connected then that was not the cause of my problems. No matter, it needed to be fixed!
Loctite it is for the butterfly screws.
Thanks again.
Emulsion block and butterfly - by Peter Naulls - 24-06-2023, 10:21 PM
RE: Emulsion block and butterfly - by Peter Naulls - 25-06-2023, 06:50 PM
