water temperature sender
John your description of the connections is exactly correct. I needed to connect to the "hot" terminals AFTER the  U bracket goes on, thus the insulators protect any stray current leakage. I had those nuts under the U bracket and the current diversion to ground caused full scale reading.
I have set everything with battery and stove etc, and the readings accord with my neighbours   cooking thermometer.
Now we're cooking!   thanks for the links which were very helpful
water temperature sender - by squeak - 02-06-2023, 08:11 AM
RE: water temperature sender - by Tony Griffiths - 02-06-2023, 10:39 AM
RE: water temperature sender - by John Cornforth - 02-06-2023, 06:02 PM
RE: water temperature sender - by squeak - 03-06-2023, 11:39 AM
RE: water temperature sender - by John Cornforth - 03-06-2023, 02:44 PM
RE: water temperature sender - by squeak - 05-06-2023, 11:31 AM
RE: water temperature sender - by John Cornforth - 05-06-2023, 07:57 PM
RE: water temperature sender - by squeak - 06-06-2023, 07:14 AM
