Timing gears
It is a sports engine with the original crankcase, crank and block. The gears have the Austin 00 and 0 timing marks so are probably original too. I'm fairly sure the damage has occurred since a PO had some engine work done about a couple of thousand miles and ten years ago (I've only taken it round the block so far). My priority is to preserve the crankcase.
Thanks Stuart and Dave, I'll give Tony a ring.
Jon, Chris Gould's guide says the front camshaft journal is larger than normal, hence the camshaft pinion has a larger centre hole. Apparently the timing gears were steel rather than iron. (A Guide to the Austin '65' and Nippy, CSW Gould, p36)
eta beaten to this by Alan and David - thanks.
Timing gears - by Colin Wilks - 22-04-2018, 03:24 PM
RE: Timing gears - by bob46320 - 22-04-2018, 04:05 PM
RE: Timing gears - by Stuart Joseph - 22-04-2018, 04:07 PM
RE: Timing gears - by Dave Wortley - 22-04-2018, 04:08 PM
RE: Timing gears - by JonE - 22-04-2018, 04:23 PM
RE: Timing gears - by Alan - 22-04-2018, 05:11 PM
RE: Timing gears - by David Witton - 22-04-2018, 05:52 PM
RE: Timing gears - by Colin Wilks - 22-04-2018, 06:35 PM
RE: Timing gears - by Charles P - 22-04-2018, 09:18 PM
RE: Timing gears - by Austin in the Shed - 24-04-2018, 05:35 PM
RE: Timing gears - by Ian Williams - 22-04-2018, 09:12 PM
RE: Timing gears - by Ray White - 22-04-2018, 09:14 PM
RE: Timing gears - by Bob Culver - 22-04-2018, 10:30 PM
RE: Timing gears - by JonE - 24-04-2018, 01:31 PM
RE: Timing gears - by dickie65 - 25-04-2018, 06:54 PM
RE: Timing gears - by Colin Wilks - 25-04-2018, 10:10 PM
RE: Timing gears - by Zetomagneto - 25-04-2018, 10:30 PM
RE: Timing gears - by Colin Wilks - 26-04-2018, 10:43 AM
RE: Timing gears - by Zetomagneto - 26-04-2018, 10:03 PM
RE: Timing gears - by Terrytuned - 29-04-2018, 10:44 AM
RE: Timing gears - by Ruairidh Dunford - 29-04-2018, 12:14 PM
RE: Timing gears - by JonE - 29-04-2018, 01:29 PM
RE: Timing gears - by Ian Williams - 29-04-2018, 08:19 PM
RE: Timing gears - by Ruairidh Dunford - 29-04-2018, 08:26 PM
RE: Timing gears - by Colin Wilks - 29-04-2018, 09:04 PM
RE: Timing gears - by Ian Williams - 29-04-2018, 09:36 PM
RE: Timing gears - by Ruairidh Dunford - 29-04-2018, 10:01 PM
