[Image: austin7brakepedalfulchrumpinlate__3000001__.jpg]
The chassis mounting should be via a nut and a wedge shaped spacer. There should be a flat on the bit between the box and the pedal so you can hold it while you undo the outer nut.
RE: What have you done today with your Austin Seven - by Reckless Rat - 01-06-2023, 02:05 PM
