Fuel starvation.
(25-05-2023, 11:03 AM)Mike Costigan Wrote: Could be a large piece of dirt (rust flake?) actually inside the tank which floats over the outlet.
(25-05-2023, 02:36 PM)Steve Jones Wrote: Does your fuel tap have a reserve? When I had a similar problem last year, pulling the reserve solved it. Turned out there was a partial blockage in the main tap stand pipe that reduced its diameter but didn't fully stop the flow and the engine was using more fuel than the tap could deliver. Taking the top of the carb off when this happened showed an empty float bowl but turning the fuel on produced a flow.
No reserve; just an elbow on the front of the tank.
I have checked there is no blockage.  The tank is rust free.  A few years ago I gave it a thorough clean and applied ethanol proof TOPAX sealant which is still holding up well.  No sign of it coming off at all ...but of course you can't see everywhere inside - even with a dental mirror on a stick!
Fuel starvation. - by Ray White - 24-05-2023, 09:33 PM
RE: Fuel starvation. - by Tony Press - 24-05-2023, 11:31 PM
RE: Fuel starvation. - by Ray White - 25-05-2023, 08:43 AM
RE: Fuel starvation. - by Howard Wright - 25-05-2023, 08:54 AM
RE: Fuel starvation. - by Ray White - 25-05-2023, 09:51 AM
RE: Fuel starvation. - by Robert Foreman - 25-05-2023, 10:15 AM
RE: Fuel starvation. - by Mike Costigan - 25-05-2023, 11:03 AM
RE: Fuel starvation. - by Howard Wright - 25-05-2023, 12:01 PM
RE: Fuel starvation. - by Ray White - 25-05-2023, 02:02 PM
RE: Fuel starvation. - by Steve Jones - 25-05-2023, 02:36 PM
RE: Fuel starvation. - by Ray White - 25-05-2023, 03:16 PM
RE: Fuel starvation. - by Ray White - 25-05-2023, 08:36 PM
RE: Fuel starvation. - by Ivor Hawkins - 25-05-2023, 10:43 PM
RE: Fuel starvation. - by Ray White - 25-05-2023, 11:14 PM
