Compression tester help
Hugh  The thread on the hose fitting is likely to be the industry standard !/4" BSP , which is compatable with PCL fittings. It may be possible to tap a 'butchered' 14 or 18mm spark plug to take the thread directly (although I haven't looked). On the other hand you could thread  the modified plug and fit a PCL male airline fitting which would plug into the female  already attached to the hose.
N.B. the DIN fittings on most LIDL kit fortunately use the same 1/4" BSP thread.
Good luck
Bob
Compression tester help - by Hugh Barnes - 15-05-2023, 08:39 PM
RE: Compression tester help - by Lowespeed - 15-05-2023, 08:48 PM
RE: Compression tester help - by Bob Kneale - 16-05-2023, 03:14 PM
RE: Compression tester help - by JohnD - 16-05-2023, 04:36 PM
RE: Compression tester help - by Stuart Giles - 16-05-2023, 09:06 PM
RE: Compression tester help - by Charles P - 16-05-2023, 09:51 PM
RE: Compression tester help - by Hugh Barnes - 17-05-2023, 07:12 AM
RE: Compression tester help - by Chris KC - 17-05-2023, 10:33 AM
RE: Compression tester help - by frequentflyer - 17-05-2023, 11:25 PM
