LED headlamp issue
LEDs draw so little current that good earth is (as others comment) absolutely essential. I'd run separate wires from each headlamp back to the battery's negative terminal. Decades ago, to brighten the ordinary bulbs, I used to solder the wires onto the bulbs and run an earth return back to the battery. The difference in light output was immediately clear and a photographic light meter (remember those?) showed a reading about 20% higher.
LED headlamp issue - by Nick Salmon - 16-05-2023, 07:36 AM
RE: LED headlamp issue - by John Cornforth - 16-05-2023, 07:43 AM
RE: LED headlamp issue - by Hugh Barnes - 16-05-2023, 07:57 AM
RE: LED headlamp issue - by Andy Bennett - 16-05-2023, 09:22 AM
RE: LED headlamp issue - by Tony Griffiths - 16-05-2023, 11:15 AM
RE: LED headlamp issue - by Colin Morgan - 16-05-2023, 11:54 AM
RE: LED headlamp issue - by Nick Salmon - 16-05-2023, 05:25 PM
RE: LED headlamp issue - by Reckless Rat - 16-05-2023, 06:02 PM
RE: LED headlamp issue - by David Cochrane - 16-05-2023, 09:57 PM
RE: LED headlamp issue - by Nick Salmon - 20-05-2023, 01:40 PM
RE: LED headlamp issue - by Reckless Rat - 20-05-2023, 03:05 PM
