Helicoil problem
Having done this recently with a sump-bolt hole - IF you can get hold of the end, then try twisting the end around (anti-clockwise) so that the 'spring' tightens smaller allowing the wire to be pulled out of the hole in an ever increasingly longer spiral - or, at least, that is what I found.
Helicoil problem - by Peter Naulls - 12-05-2023, 11:31 PM
RE: Helicoil problem - by jpsmit - 13-05-2023, 03:42 AM
RE: Helicoil problem - by Chris KC - 13-05-2023, 04:06 AM
RE: Helicoil problem - by Howard Wright - 13-05-2023, 06:55 AM
RE: Helicoil problem - by jonblob33 - 13-05-2023, 07:30 AM
RE: Helicoil problem - by Colin Cooke - 13-05-2023, 07:46 AM
RE: Helicoil problem - by squeak - 13-05-2023, 11:22 AM
RE: Helicoil problem - by David Stepney - 13-05-2023, 01:26 PM
RE: Helicoil problem - by Colin Morgan - 13-05-2023, 04:31 PM
RE: Helicoil problem - by John Mason - 13-05-2023, 10:04 PM
RE: Helicoil problem - by Peter Naulls - 13-05-2023, 11:01 PM
RE: Helicoil problem - by Peter Naulls - 15-05-2023, 10:15 PM
RE: Helicoil problem - by Howard Wright - 16-05-2023, 07:04 AM
RE: Helicoil problem - by Peter Naulls - 16-05-2023, 08:23 AM
RE: Helicoil problem - by frequentflyer - 17-05-2023, 11:31 PM
RE: Helicoil problem - by Peter Naulls - 20-05-2023, 09:42 PM
