Helicoil problem
They come out easily if you can unpick enough of the end to grab with long nosed pliers or side cutters.
Then they can be unwound out, they collapse a bit, and so loosen.
Try tapping the hole a bit deeper (you need the tap the correct size) before inserting a new one.
If you don't want to do that, cut the next insert short with a sharp pair of side cutters, de-burr the end with a small file before inserting.
Helicoil problem - by Peter Naulls - 12-05-2023, 11:31 PM
RE: Helicoil problem - by jpsmit - 13-05-2023, 03:42 AM
RE: Helicoil problem - by Chris KC - 13-05-2023, 04:06 AM
RE: Helicoil problem - by Howard Wright - 13-05-2023, 06:55 AM
RE: Helicoil problem - by jonblob33 - 13-05-2023, 07:30 AM
RE: Helicoil problem - by "Slack Alice" Simon - 13-05-2023, 07:42 AM
RE: Helicoil problem - by Colin Cooke - 13-05-2023, 07:46 AM
RE: Helicoil problem - by squeak - 13-05-2023, 11:22 AM
RE: Helicoil problem - by David Stepney - 13-05-2023, 01:26 PM
RE: Helicoil problem - by Colin Morgan - 13-05-2023, 04:31 PM
RE: Helicoil problem - by John Mason - 13-05-2023, 10:04 PM
RE: Helicoil problem - by Peter Naulls - 13-05-2023, 11:01 PM
RE: Helicoil problem - by Peter Naulls - 15-05-2023, 10:15 PM
RE: Helicoil problem - by Howard Wright - 16-05-2023, 07:04 AM
RE: Helicoil problem - by Peter Naulls - 16-05-2023, 08:23 AM
RE: Helicoil problem - by frequentflyer - 17-05-2023, 11:31 PM
RE: Helicoil problem - by Peter Naulls - 20-05-2023, 09:42 PM
