Rear Main Bearing Clearance
If I remember the original rear roller bearing mains may have had a special reduced inner clearance bur of copurse these are no longer available.
The standard roller bearing SKF CRM 10 or RHP MRJ 1 1/4 may have slightly larger clearance but 2 thou should be OK - as mentioned the centre bearing must be line bored.
The standard slight rear bearing rumble is usual.
Rear Main Bearing Clearance - by Graham Barker - 02-05-2023, 08:03 AM
RE: Rear Main Bearing Clearance - by Chris KC - 03-05-2023, 12:05 PM
RE: Rear Main Bearing Clearance - by Chris KC - 04-05-2023, 08:58 AM
RE: Rear Main Bearing Clearance - by Tony Press - 04-05-2023, 11:34 PM
