Back to the Wolseley Eight.....I had only ever seen one and that is at Lord Nuffield's home. I then discovered that my 19 47 Rover12 tourer had the distributor from one! It's Lucas pat number was one different from the correct Rover unit! Some previous owner must have thought...only one number different - that should work! Well, it rotated the same way!
Amazingly I found a correct unused one, it made a significant improvement☺
Anyone need a Wolseley Eight distributor? I don't think it will suit a Seven, but you needvery know....
David
RE: What have you done today with your Austin Seven - by David.H - 02-05-2023, 08:05 PM
Users browsing this thread: 26 Guest(s)
