Charging Diagnostics
Best to check the output
You can use a standard drill to turn the shaft(make sure it’s the correct rotation)
When I had a similar problem turned out to be brushes
Use a 12/6 volt bulb
Regards
Tim
Charging Diagnostics - by RupertW - 30-04-2023, 01:00 PM
RE: Charging Diagnostics - by Dave Mann - 30-04-2023, 05:08 PM
RE: Charging Diagnostics - by RupertW - 30-04-2023, 07:22 PM
RE: Charging Diagnostics - by Stuart Giles - 30-04-2023, 08:56 PM
RE: Charging Diagnostics - by RupertW - 01-05-2023, 09:58 AM
RE: Charging Diagnostics - by Tiger - 01-05-2023, 11:20 AM
RE: Charging Diagnostics - by RupertW - 01-05-2023, 12:24 PM
RE: Charging Diagnostics - by Tiger - 01-05-2023, 01:29 PM
RE: Charging Diagnostics - by RupertW - 01-05-2023, 02:45 PM
