Charging Diagnostics
I have both a digital one and a very cheap analogue one with a needle, and neither of them seem to be any good!
I have ended up taking the dynamo off the car and put it on the bench as I wasn't having any luck.
With the terminals bridged and a a positive lead directly to the battery, and a negative to the body, it does motor.
It only seems to be turning at what I'd estimate to be a few hundred RPM. Is that about what you'd expect from a healthy dynamo or should it be turning with a fair bit of speed?
Charging Diagnostics - by RupertW - 30-04-2023, 01:00 PM
RE: Charging Diagnostics - by Dave Mann - 30-04-2023, 05:08 PM
RE: Charging Diagnostics - by RupertW - 30-04-2023, 07:22 PM
RE: Charging Diagnostics - by Stuart Giles - 30-04-2023, 08:56 PM
RE: Charging Diagnostics - by RupertW - 01-05-2023, 09:58 AM
RE: Charging Diagnostics - by Tiger - 01-05-2023, 11:20 AM
RE: Charging Diagnostics - by RupertW - 01-05-2023, 12:24 PM
RE: Charging Diagnostics - by Tiger - 01-05-2023, 01:29 PM
RE: Charging Diagnostics - by RupertW - 01-05-2023, 02:45 PM
