Charging Diagnostics
Thank you, that's very helpful - I hadn't noticed the terminal marks on the cover.
I've had an attempt with terminals linked and both multimeters but annoyingly both multimeters seem to be malfunctioning so I can't get any clear readings. I've tested both on a seperate 12v battery and they're all over the place, so fairly sure it's not electrical interference and my fault for buying cheap equipment. They did seem to give some sort of reading when revved up but a bit all over the place. I'll see if I can dig out a 12v bulb from somewhere and see if I can test things the more old fashioned way.
Charging Diagnostics - by RupertW - 30-04-2023, 01:00 PM
RE: Charging Diagnostics - by Dave Mann - 30-04-2023, 05:08 PM
RE: Charging Diagnostics - by RupertW - 30-04-2023, 07:22 PM
RE: Charging Diagnostics - by Stuart Giles - 30-04-2023, 08:56 PM
RE: Charging Diagnostics - by RupertW - 01-05-2023, 09:58 AM
RE: Charging Diagnostics - by Tiger - 01-05-2023, 11:20 AM
RE: Charging Diagnostics - by RupertW - 01-05-2023, 12:24 PM
RE: Charging Diagnostics - by Tiger - 01-05-2023, 01:29 PM
RE: Charging Diagnostics - by RupertW - 01-05-2023, 02:45 PM
