Loose Front Spring Bolts
I have removed the packers using the procedure suggested by Malcom and it was quite easy. The soft packers are of a material called hardboard in NZ. It is a dark brown material comprised of wood fibre and glue. It is often found as a cheap backing for wooden cabinets and chests of drawers. The packers were roughly cut and didn't match up with the full length of the aluminum packers. So I have thrown them away and reassembled using only the aluminum.packer. Time will tell if there was an important reason for the soft packers.
Loose Front Spring Bolts - by Graham Barker - 16-04-2023, 10:38 AM
RE: Loose Front Spring Bolts - by Colin Morgan - 16-04-2023, 12:41 PM
RE: Loose Front Spring Bolts - by Graham Barker - 16-04-2023, 08:31 PM
RE: Loose Front Spring Bolts - by Tony Press - 16-04-2023, 11:59 PM
RE: Loose Front Spring Bolts - by Graham Barker - 17-04-2023, 07:42 AM
RE: Loose Front Spring Bolts - by Malcolm Parker - 17-04-2023, 09:00 AM
RE: Loose Front Spring Bolts - by Graham Barker - 22-04-2023, 06:23 AM
RE: Loose Front Spring Bolts - by Malcolm Parker - 22-04-2023, 09:47 AM
RE: Loose Front Spring Bolts - by Tony Press - 22-04-2023, 11:53 PM
RE: Loose Front Spring Bolts - by Graham Barker - 29-04-2023, 07:00 AM
RE: Loose Front Spring Bolts - by Tony Press - 29-04-2023, 11:56 PM
RE: Loose Front Spring Bolts - by Charles P - 30-04-2023, 08:06 AM
