How does electrical interference travel?
Thanks for the basic explanations, this all helps figuring out a solution.
I tried tin foil Colin. Didn’t make any difference. Wrapped the flasher unit.
Sounds like I’m lucky really, because it’s only the indicator dash bulb that’s a problem.
I very happy with the LED’s. Very low battery drain. Means I can use the side lights as day time driving lights.
I’m now sourcing a couple of capacitors.
John, are the suppressed plug caps simply the ends that clamp onto the spark plug?
It’s a pity to have to remove the brass nuts, I think they look more authentic.
RE: How does electrical interference travel? - by Lowbarn - 20-04-2023, 09:09 PM
